Go Back   Offshoreonly.com > Owner's Forum > Baja
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 03-22-2005, 07:56 PM   #1
JasonSmith's Avatar
1999 Baja 29' Outlaw
29 outlaw cable lenghts
I hava a 29 outlaw with mechanical drive indicators. Does anyone know what length the cables are? I contacted Baja and they sad they could be 4 different lenghts.
JasonSmith is offline   Reply With Quote
Old 03-22-2005, 08:39 PM   #2
Charter Member #34
Dock Holiday's Avatar
Re: 29 outlaw cable lenghts
If you are going to replace them, go ahead and pull them out for an accurate measurement.
I changed mine this winter and did a rough measurement and ended up short.
They came out easy and went back in easy. Go with the high quality red cables. They work great and are not stiff like the ones Baja uses.
Good luck
Dock Holiday is offline   Reply With Quote
Sponsored Links
Old 03-22-2005, 09:08 PM   #3
JasonSmith's Avatar
Thanks, I was araid they would be too hard to re-route. Not too difficult sounds like?
Old 03-22-2005, 09:30 PM   #4
Charter Member #34
Quote:
It really is easy. The hardest part is connecting the ends. By yourself you should be able to take the old ones off and connect the new ones in two hours tops without rushing.
Mine had a black plastic clam shell cover on the outside of the transom. It forced the cables to make a 90 degree bend.
I took it off and replaced it with some nice 45 degree stainless fittings as shown in this picture. Hope you can make it out okay.
It did leave the holes from the black plastic one, but I filled them with white silicone and put the screws back in. Had them repaired and gelcoated over a few weeks ago when we had the swim platform powercoated.
Look luck
Dock
Trackbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Bravo 1 Shift cable retainer let go of cable DrFeelgood Drives and Lower Units 5 11-05-2007 10:42 AM
2002 29' Outlaw SST.... Fast Outlaw FOR SALE Jakester Baja 5 07-16-2006 09:33 PM
Looking to sell 29 outlaw or trade for a 25 outlaw? ttb Baja 20 08-25-2005 12:07 PM
FYI- All cable lenghts for a TG BillR Cigarette 0 11-16-2004 12:03 PM
02 292 Fast Tech, 04 29 Outlaw SSE, or 04 30 Outlaw bikinilover Baja 35 08-17-2003 12:11 PM
Search Engine Optimization by vBSEO 3.2.0
