Quote:
Originally Posted by AIR TIME
it should with the ITS set up you can put the drive height up higher than stock like 2''. other wise your drive will be to deep.
Sounds good when you say it will work
I do beleive I have somwhere about 5" high mount of the transom today. At this stage im not too worried about putting the drive to low.
I will soon have the drive and ITS in my hand and then I will know more about the hight. Perhaps I need to remove the 1" spacer?
Im more concerned about if it will "fit" the boat with an set back of some 7"? I already have an notch.
On the other hand I believe the new Bananas that have an OutBoard have a greater set back than 7"?
I have heard that not all boats handle better with a set back.
