Quote:
Originally Posted by Skullkrusher
See if you can get someone to translate into english for you. That post makes no sense.
I bought a "bad azz race tuned" 2.4 from private ad
seller was to re ring himself
1 piston went down with under 10 hrs. easy time..
on teardown...
A dab of cement all 6 slosh plate (ground down) screw heads (in carb bowls ) was found
by Marine tech friend Terry and I
a gray hunk of cement was also found loose in bowl
should cement be used in carb bowls ?
can motor have no ser # 's ?
