Go Back   Offshoreonly.com > Owner's Forum > Carrera
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 05-05-2009, 06:42 PM   #1
NEED A BOAT NAME
kreed's Avatar
FORMULA 382 FASTECH
Annoying Porpusing.........
Has anyone experienced the bow of their boat nose diving to the left under acceleration? Its a SS8M with a single BB Chevy. Just started doing it after installing a new engine. It made almost 700 F/P torque so I assuming thats the problem. It is also porpusing after 60 mph which it didnt do before. Both problems are very annoying and I need some advice on how to correct them......Thanks.
kreed is offline   Reply With Quote
Old 05-05-2009, 08:00 PM   #2
JC Performance Engines
Stormrider's Avatar
1995 Pantera 24SE - SOLD
have u talked to throttle up yet?
are your tabs even?
You may want to post this in the general forum to get a better response.
With great power, comes great responsibility.
WAS Powered by JC Performance & a roll of Duct Tape.
Stormrider is offline   Reply With Quote
Sponsored Links
Old 05-06-2009, 07:14 AM   #3
NEED A BOAT NAME
kreed's Avatar
FORMULA 382 FASTECH
Thanks Stormrider, I will do that.
Old 05-06-2009, 10:45 AM   #4
NEED A BOAT NAME
kreed's Avatar
FORMULA 382 FASTECH
I had put a call into BBlades. Dont mean to put you on the spot, but who do you prefer and why? PM me if you want. Would a shorty work instead of raising the drive? Prop work would stop the nose diving? Thanks for the advice.
Old 05-06-2009, 10:52 AM   #5
1988 CARRERA SS8M / 509" / Bravo
ThrottleUp is no longer doing prop work on any props except
their own Throttle-Up in house made props,
at least that is what Julie emailed me.
Sounds like your drive is too low in the water.
HTRDLNCN is online now   Reply With Quote
Old 05-06-2009, 11:48 AM   #6
NEED A BOAT NAME
kreed's Avatar
FORMULA 382 FASTECH
Yes , its a bravo 1. I think I will start by talking to someone about the prop first. Hopefully getting the nose diving situation taken care of, and then focus on the porpusing. Even trimming doesnt stop it. Im taking it out today and adding fuel to the boat. Only had 1/4 tank of gas when I tested it. Maybe more weight will help ?
Old 05-06-2009, 11:54 AM   #7
rchevelle71's Avatar
1982 Pantera 24sport
What prop are you using??
rchevelle71 is offline   Reply With Quote
Old 05-06-2009, 12:53 PM   #8
NEED A BOAT NAME
kreed's Avatar
FORMULA 382 FASTECH
Daredevil- Nose diving meaning the bow of the boat is leaning down and left. Ive tried correcting it with dropping right trim tab alittle, but it still wants to lean under acceleration. Like the torque of the motor is pushing the nose down and to the left, thats after I get through the porpusing.......Its really annoying.
Old 05-06-2009, 12:56 PM   #9
NEED A BOAT NAME
kreed's Avatar
FORMULA 382 FASTECH
Im using a stock 28P Bravo 1. I think its alittle too big. the motor makes peak power at 5500 RPM, I can only push the boat to about 5200 rpm. Lab finish??????????
Old 05-06-2009, 02:00 PM   #10
Stormrider's Avatar
Step 1: Get brett on the phone!
Trackbacks are Off
Refbacks are Off
Search Engine Optimization by vBSEO 3.2.0
