Quote:
Originally Posted by cody_white83
i took the spacers out but haven't put up any new pics how do i make the bottom perfect and will it help with the speed? just wondering if it would make any difference and if its worth the work.
I did a full blue print on my 30' Chris-Cat outboard Pro-Stock boat, and it added maybe one or two MPH at best. The bottom is actually pretty good out of the mold. Also, to do it right you really need to flip the boat upside down. If you don't, you really aren't going to do the job correctly and any gains will be minimal.
Judging from the photos of your drives, etc., you could gain a lot more from other areas. Save the blue printing for when everything else has been done. Get your drive heights and set backs correct, try some different props, try a little weight savings, etc. All of these areas will yield you as much or more than a blue print to the bottom and will be much easier and less expensive to do. Blue printing should be last on your list when there is nothing else left that will get you any gains.
Just my 2 cents!
Tom
Total Marine
