Removing Grab Bars On Bolsters?
1 Post
Re: Removing Grab Bars On Bolsters?
They look the same some what as the Bullets. Look under the back side & there s/b 2 round holes on the very bottom. If there are be carefull with the hands. Could be a little rough inside.
www.sunriseuph.com
But it begs the question, why are you taking them off?? Repainting?
FIERCE ALLEGIANCE
A little additional info. You'll have to remove the seats from the stands. In the corners there are two holes that will probably have panels covering them. A tight fit but you can stick your arm thru them to reach the nuts on the handles.
