Go Back   Offshoreonly.com > Owner's Forum > Cigarette
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 03-16-2009, 08:09 AM   #1
ciaoderhead's Avatar
MTI, Pioneer, Cig's sold:(
Engine hatch mirror removal
Any tips on removing the mirror on an engine hatch? Thought about using wooden door shims (wedges) so I don't gouge the gelcoat.....not trying to re-use the mirror but don't want to f'up the hatch.
ciaoderhead is offline   Reply With Quote
Old 03-16-2009, 08:29 AM   #2
O.C.Barry's Avatar
28 Cigarette SS, 20 Cigarette
Quote:
We took one off of our old TG. Wooden shims will work but you might have to make something more stout that door shims. The mirrors are held on with 3M 4200 so it's not a fun job. Good thing you don't want to reuse the mirror, ours came apart in pieces, be sure to wear eye protection. There will be lots of 4200 left on the hatch. Our gel coat was well - cured ( 8 years old) so we used new razor blades and laquer thinner, the gel coat was unhurt.
Barry
Thanks, Barry
"It's better to burn out than fade away!"
O.C.Barry is offline   Reply With Quote
Sponsored Links
Old 03-16-2009, 11:29 AM   #3
Nothin.. and it sucks !
Forget it !!! Just cover it up with what ever you are thinking of using. If you wanted to paint it buy a piece of White laminate and paint that and stick it to the mirror. It is the 2nd worst job on the boat, is removing the tanks.
tanner is offline   Reply With Quote
Old 03-16-2009, 09:32 PM   #4
1997 lip ship cig
Has anyone removed and replaced the mirror ? Where did you get mrror from? cig? Or was it custom made Thx, greg
greg bakker is offline   Reply With Quote
Old 03-17-2009, 08:59 AM   #5
barron's Avatar
Boatless but looking!
Quote:
Hows that boat running I still miss it!
barron is offline   Reply With Quote
Old 03-17-2009, 09:37 AM   #6
Tanner, your right, major PIA to remove but leaving it is not an option. Was hoping the mirror was just stuck in places but it is fully bonded.
Used DeBond years ago to remove an engine bracket and just ordered some more to try. I'll let you know how it works this go round.....
http://www.marineformula.com/
Old 03-17-2009, 07:26 PM   #7
Make sure you have plenty of band aids !!!
Old 03-17-2009, 07:28 PM   #8
ust a thought... maybe a heat gun !! you dont care about the plastic, so maybe the heat will soften up that adhesive up .
Old 03-17-2009, 10:27 PM   #9
1997 lip ship cig
Hey, BARRON did you buy the boat from derrick key through phil ? The boat is awesome. When i bought the boat it had bad gimbal rings and the drives were not aligned properly with the tie bar. I fixed everything from rings to new floor to interior etc. I have had it 4 years and love it.Do you now have a fountain?
Old 03-18-2009, 08:52 AM   #10
Forum Regulator
Sydwayz's Avatar
Active Thunder 37' & other Factory boats, 13' Mini Hawk
Lin, I assume you have the hatch removed, and flipped downside up. Perhaps you could cut it into 2" strips with a properly set router, and individually pry each strip up with a strong putty knife. Just an idea--I've never tried it.
Brian T.
Active Thunder Factory Rep.
Web: ActiveThunderBoats.com
Email: brian(a)activethunderboats.com
Sydwayz is offline   Reply With Quote
Trackbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
TG Engine Hatch Removal Tricks Croozin2 Cigarette 6 08-29-2007 10:05 PM
Engine Hatch Mirror PremierPOWER Formula 2 03-25-2007 07:31 AM
Engine hatch mirror rattle LV Formula 10 03-12-2007 12:00 AM
Custom carpet and engine hatch mirror bshzba General Boating Discussion 8 10-15-2006 06:48 PM
under hatch mirror Scarabdude General Q & A 35 03-04-2005 04:49 PM
Search Engine Optimization by vBSEO 3.2.0
