Question for the Bullet Electrical Guru's
Probably. The Bullet will be the last to go under the antifreeze, usually late October. The problem in October is if it's cloudy or after the sun sets, it might get cold. Also in October a 20 foot boat is big on The Lake. You bringin' The Gun back?
Planning on it your more than welcome to ride with me if you like.
cubby light
My cubby area has a door with "Bullet" cut out so that when the light is on, the Bullet is illuminated. The switch is the forward rocker switch on the switch panel. Hope this helps.
Hugh Mills
88 Bullet
Hugh Mills
88 Bullet
Thanks gents, that was it, the forward switch that is unmarked. I don't have a light there, I'm playing with a couple of bare wires. I thought I checked all the switches...but that must've been after the bottle of whiskey!
