Any factory 28ss w/ big blocks? How would it handle?
Not sure, it came with the boat. The transom is a lot taller than the Cigs so plenty of room for a swim platform. Really nothing custom about it. Have you thought about making one with cutouts for the exhaust. Or maybe just doing a single step platform in the middle of both exhaust.
The TRS's and K planes take up the transome below the rub rail, I am not use there is a place for a swim platform, unless go back to the 180 degree risers and run the exhaust back to the original locations.
The only time I have ever seen my drain plugs was when the engines were out of the boat. To prep them for freezing weather, you fire theach motor up using a 5 gallon bucket with street water and a garden hose refilling the bucket. When the engines get to operating tempature you switch the bucket to a 50/50 mix and continue pumping into your running engine untill you have used all 5 gallons of 50/50 up, then shut that engine off and do the other. A bit messy, but it does fill the motors/exhaust systems with antifreeze.
