speed question >
speed question
speed question
Old 09-26-2013, 05:27 PM
Default speed question
What would a 94 38 top gun with brad smith 750hp blower motors run for speed and how reliable are the motors.
Also how do the old hulls ride compared to the new ones.
I'm looking for a fast wave crusher but not to much $$
outlw36 is offline
Old 09-26-2013, 06:19 PM
O.C.Barry's Avatar
Our old 94 TG ran right at 80 with two people in it and half full of fuel. Twin 735 HP blower motors. That was with SSM 3A's and transmissions, Bravos will be faster, but with that much HP, you'll need some IMCO or Teague parts to gain drive life.
Thanks, Barry
Driver - High's Fuel Your Journey Cigarette Racing Team #598
O.C.Barry is offline
Old 09-26-2013, 06:49 PM
From what I hear those should be as if not more reliable than any other 700's. trs boat will run 80-82 but prop slip will be a little high unless it has nose cones. 3a's maybe slightly faster, bravos will be slower because they will be broken.
Unlimited jd is offline
Old 09-26-2013, 08:37 PM
buck183's Avatar
Would said boat by chance be listed in the classifieds on OSO? If so, would it by chance come with a gooseneck trailer? If so, the guy that built the boat reads this forum everyday. He could get you the exact info you look for.
Buck
buck183 is offline
Old 09-26-2013, 09:03 PM
carter38's Avatar
If it's that boat you can pm me or call me if you like 918-232-3503. My old gun with Smith Power 750's would run mid 80's pretty consistent. Motors made a little bit more that 750 though.
carter38 is offline
Old 09-26-2013, 09:19 PM
mmb
Your old boat flirts with 100mph! Think we are going to do 6's next year!
mmb is offline
Old 09-27-2013, 06:46 AM
Quinlan's Avatar
[, bravos will be slower because they will be broken.[/QUOTE]
Now that right there is Funny!
Quinlan is offline
Old 09-27-2013, 09:46 AM
cigrocket's Avatar
Now that right there is Funny![/QUOTE]
Straight Bottom Guns with more then 500HP are Bravo Eaters. Save yourself the headache and by a SSM boat.
cigrocket is offline
Old 09-27-2013, 10:55 AM
carter38's Avatar
Straight Bottom Guns with more then 500HP are Bravo Eaters. Save yourself the headache and by a SSM boat.[/QUOTE]
I'm a big believer in the way it's driven. Not trying to start a pissing match, but I've been around many guns with 500+ hp and have had one myself with 750's. I broke 1 in 3 years.
carter38 is offline
Old 09-27-2013, 11:20 AM
cigrocket's Avatar
I'm a big believer in the way it's driven. Not trying to start a pissing match, but I've been around many guns with 500+ hp and have had one myself with 750's. I broke 1 in 3 years.[/QUOTE]
It also depends on the water conditions and the driver. I do believe that you could make them last, But standard Bravos were never designed to hold more then 500HP and then you factor in the weight of the Top Gun. If you drive it hard or pop out of the water and don't throttle back, you could toast one. Anyway you look at it, the ride of the straight bottom gun is worth it.
