Quote:
Originally Posted by birdwillfly
Thanks for the replies... My plan is for the boat to spend most of its time in the ocean. We live close to it. For a budget, mine will go farther than lots of folks as I can do my own engine building less machining time. I would hope to spend no more than 10,000 on the boat in terms of uprating/repowering parts. With a practical limit of ten large what would be the most bang for the buck? I already am equipped with a nice power steering unit for the twins. I could add more money later but I don't want to spend a whole lot more on the boat. The motors are your standard 140 hp GM stringers with OMC 400's. Thanks, Roy
IMO,
with the twin engine set up, $10k would probably be consumed real quick if you do a major re-rig like to a couple small blocks and in the end you may be spending a lot more than ever imagined.
1st, I would see what the tansom holes would accept and look for a couple takeouts that may bolt up with little glass work.
If your limited to the specific outdrives without glass work, then i would vote for a refurbish to the outdrives and engines with what you have and enjoy it for what it is-which is a cool solid boat platform.
Then when you have enjoyed the boat to its full potential, sell it and move into something that is closer to what you may want later.
good luck
