[QUOTE=T2x;2683672]
Quote:
Originally Posted by StephenA
Be VERY careful........
Shadow/Chris Cats have very deep forward sponson areas and need bow lift to prevent broaching at speed......
Arnesons run at negative shaft angles....so you will need high rake props to offset this shortcoming......and make no mistake....it is a shortcoming.
The Miss America Accident I believe was with Kaama drives, not Arnesons..... and the reason that two fatalities occurred was because there was no easy exit built into the canopies and the occupants drowned after a drive ripped off the transom causing a barrel roll.
T2x
I remember that race. It was a very traggic day here on the gulf coast. Here is the clip from the local panama city beach newspaper that I found in the archives.
"Thomas Brandt, 38, of Gulf Stream and Donald Wright, 45, of Fort Lauderdale, died when their Spirit of Miss Liberty powerboat crashed during the running of the inaugural Sheffield Oil Unocal 76 Offshore Classic held April 16 off Panama City Beach.
Offshore Power Boat Racing Association president John Kenyon, who is also the association's chief boat inspector, declined comment on the report because of a pending lawsuit, as did Sandra Brandt, widow of the driver. Efforts to reach the widow of Donald Wright were unsuccessful.
MEN TRAPPED
Brandt and Wright drowned when their 1984 30-foot Chris Craft boat caught a ``freak wave,'' barrel rolled and flipped end over end at least once, according to the report. The boat landed upside down and sank by the stern.
The Spirit of Miss Liberty was the only boat in the 33-boat field to use an enclosed canopy. The canopy was basically an aluminum box shaped to fit the contours of the boat, including a solid aluminum floor, with a series of five vertical posts from floor to ceiling. The windows in the canopy were aircraft-type plexiglass, and solidly bolted to the aluminum frame.
Brandt, the driver, and Wright, the throttleman, entered and exited the canopy by two ``man holes'' in the stern that measured two feet by two and one-half feet. They were the only exits from of the boat.
The boat sank stern first, in approximately 15 feet of water in 43 seconds, filling the canopy with water.
According to the FMP report, Brant and Wright were alive and conscious following the crash, as evidenced by unstrapped seat belts and shoulder restraints.
However, due the buoyancy of their life jackets, the two men were forced against the windshield--instrument panel area where they were unable to swim, or were unable pull themselves down to the ``man holes'' and escape.
The OPBRA, which staged the race, had several rescue crews available, but none was able to save the two racers."
