Help with Cleaver Prop mounting on TRS
These props also use the bravo hub ??
The spacers are correct. Back when I switched from SSM II's to TRS I had a set of 21' 3 blade cleavers, I too had to use the spacers. As far as the cleavers being faster, I doubt it. You have to remember that the TRS is not a surfacing type of drive. The cleavers were good in their day (30 years ago), but the bravos are a better prop.
