Make a Marine EFI code tool for less than $1.00 >
Old 07-07-2007, 08:39 AM
Default Updating Link
Just wanted to update the link and add part numbers
http://www.powerandsignal.com/docs/Catalog/met150.pdf
(page 17)
black tower cover (my name for it) PN - 12045808
TPA PN - 12124264
Not sure if they still sell to public but I'm calling Monday to see. Thanks for the original info.
Dannyhightower is offline
Old 07-31-2007, 02:02 PM
So then when I hook up the paper clip to A and B term. then I can start engine and set base idle?
Spooln is offline
Old 07-31-2007, 02:35 PM
Dave_N's Avatar
I would start the engine first, if it's a MEFI 1you will need to increase the RPM to around 1600 before you put the jumper in. If it's MEFI2 ,3 or 4, you just start the engine and put the jumper in, the RPM will automatically increase. Then set the timing.
Dave
Dave_N is offline
Old 07-31-2007, 03:17 PM
Originally Posted by Dave_N
Blake,
You can't set the timing at all. Base timing is controlled by the computer and is not adjustable. You can loosen and turn the distributor, but it only aligns/misaligns the rotor with the distributor cap, it does not change the timing.
Dave
I have to disagree with this. Turning the distributor sets the base timing when in service mode. In normal operation the computer or ignition module controls the amount of advance.
Rene
oldandtired is offline
Old 08-01-2007, 12:16 AM
Dave_N's Avatar
Rene
You are correct if your talking about a MEFI (pre 2002) engine. I was referring to the later model ECM555 engines that do not get the ignition reference pulse from the distributor, they use a crank and cam sensor. So turning the distributor will not change the timing and there is no Service Mode on these systems.
Dave_N is offline
Old 08-04-2007, 11:51 AM
Default Timing
So how do I tell what MEFI I have on a 1995 Baja caliber twlight with 350 mag? And in order to adjust advance timing I need a scan tool or no? What is the must I can advance timing too? Thanks for the help
Spooln is offline
Old 09-24-2007, 11:22 PM
Dave:
Just thanks for posting.. :-)
dcg9381 is offline
Old 05-04-2008, 02:05 PM
Dave_N's Avatar
For information on how use a test light instead of a LED to read trouble codes, see update of the first post in this thread.
Dave
Dave_N is offline
Old 09-26-2010, 11:06 PM
Default code reader reads zero.
hi dave.
looks like you know a lot about efi's.
i made that tool that you explained us, but in my case with the engine off, just the key on, i have code 12.
my boat is a monterey 98 5.7 efi digital ignition, still misses and backfires on top speed, i already checked everything possible and changed, with no success.
should i plug the tool with the engine running? or buy a better scan tool to find the codes, or i dont have no codes and the problem gotta be something else?
thanks
monterey98 is offline
Old 07-25-2012, 08:00 PM
Default Make a Marine EFI code tool for less than $1.00
does this work for a 2005 mpi 5.o
sanman02 is offline
Quick Reply: Make a Marine EFI code tool for less than $1.00
