Drive motor
Maybe someone can help. It could also be the switch.
If the pump runs when you hit the down switch then it's not the solenoid. It could be your trim rams are frozen. It happened to my dads boat(Bravo1). Had to have the rams rebuilt. The kits are about $60 each. Just a thought.
Have someone kick the drive downwards when you hit the buttom! If the trim motor runs ofcourse! If the drive has been sitting in the far most up position for some time it sometimes gets stuck and needs some help to break loose.
