I need to check the timing on a 91 454 carb engine,
no vacuum advanvce on distributor.
I think you need to cut a wire.
which wire and where is it located
thanx
DONT CUT ANY WIRES,with the boat running in the water,and up to operating temperature,in neutral,check total timing at 3000 rpm,[you must use a timing lite that shows total advance].set it at 32 degreese advance,
You do not need to do anything special. Just hook up the timing light. Chances are it has a V8-24 module and you will need to rev to 3700rpms to check full advance.
thanx guys, i'll get her done tomorrow, this is an old boat i'm selling and trying to get the bugs out, was running hot after
taking heads off so i am hoping it is timing.
edit, got it done runs perfect, temps back to normal.
thanx
