Go Back   Offshoreonly.com > Technical > Do It Yourself, Boating on a Budget
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 08-17-2009, 09:53 AM   #1
2000 33 Outlaw
Can a bad Gimbal bearing...
break up so bad that it stops/seizes the motor with a loud bang .. and makes it sound like theres rocks boucing around in there trying to restart?
That`s what happened to me. Two hours later..after getting it home, I could only duplicate the noise once. Thought for sure it was a rod knock but motor runs fine now.
Trying to figure out what such loud noise could be if not motor internals..
ICDEDPPL is offline   Reply With Quote
Old 08-17-2009, 10:42 AM   #2
1BIGJIM's Avatar
Location: Omaha, Nebraska. Boat on the Mighty Mo! Longest river in the USA!
Pachanga-27 Twin 502s
Take the outdrive off and start it on a hose. Then you can look at the u-joints and see if they are bad. Also check the gimble bearing.
1BIGJIM is offline   Reply With Quote
Sponsored Links
Old 08-17-2009, 11:41 AM   #3
seafordguy's Avatar
Cigarette - Cafe Racer
It could have seized, locked up and spun the coupler??
I would spend 10 minutes pulling the drive off and then you'll know for sure.
seafordguy is offline   Reply With Quote
Old 08-17-2009, 04:48 PM   #4
2000 33 Outlaw
It`s going in for bellows replacements so I guess it may even be a good time for it to break.. lol
Old 08-17-2009, 05:26 PM   #5
Thunderstruck's Avatar
1998 32' Active Thunder
Saw your post in the AT section and thought of a drive failure since the motor runs OK now. Looks like your on top of it.
Long time cult member.
Thunderstruck is offline   Reply With Quote
Old 08-18-2009, 10:29 AM   #6
Depending on how old your drive is determines how much you can be Phucked by a gimble bearing, On older bravos there have been cases where the gimble bearing failed and broke off the whole section that it fits into, Boss's and all leaving a gaping hole big enough to suck up a full sized beach towel and spit it in the bilge (ax me how I know) I think it's worth the money to change it at least every other year whether you think it's bad or not.
fastdonzi is offline   Reply With Quote
Trackbacks are Off
Refbacks are Off
Search Engine Optimization by vBSEO 3.2.0
