Go Back   Offshoreonly.com > Technical > Do It Yourself, Boating on a Budget
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 08-24-2009, 10:05 PM   #1
tim brown's Avatar
1997 35 lightning, 1996 29 fever
need help disc brakes
if I remove my drum brakes and replace with disc do I need to remove the residual valve ? if yes , how do I remove the master cylinder ? thanks Tim
tim brown is offline   Reply With Quote
Old 08-24-2009, 10:13 PM   #2
1979 Carrera SS7m, and more small boats
Pretty sure you have to remove the residual valve, but not 100% certain. You live in the CINCI area I would call DRY DOCK over off 747 they deal alot in trailer parts.
paston1 is offline   Reply With Quote
Sponsored Links
Old 08-24-2009, 10:25 PM   #3
Ginger or Mary Ann?
US1 Fountain's Avatar
1999 32 Fountain Fever, 1995 Baja 29' Cruiser
Some just use an ice pick to poke thru the end and rupture the valve w/o disassembling the MC.
US1 Fountain is offline   Reply With Quote
Old 08-24-2009, 10:41 PM   #4
Just a squirrel...
c_deezy's Avatar
88 240 with a new lease on life
Yes you need to pull out the valve. Its just a matter of pulling the snap-ring out of then end of the master cylinder with the plunger, removing the piston, removing the valve and re-assembling in reverse order. To remove the master cylinder from the coupler, remove the brake hose, take out the four bolts (number 17 on page 9 of the Dico 10 doc below), slide the master cylinder out of the back of the coupler.
Tim - What coupler do you have Dico 10 or 20? They are similar, but the 20 has an extra roll pin and guide pin.
Here is a parts breakdown for each:
Dico 10 - http://shop.easternmarine.com/downlo...an_model10.pdf
Dico 20 - http://shop.easternmarine.com/downlo...ator2.6923.pdf
c_deezy is offline   Reply With Quote
Old 08-24-2009, 10:54 PM   #5
Just a squirrel...
c_deezy's Avatar
Oh and you'll also need a reverse lockout solenoid and a 5-pin trailer harness to actuate the reverse lockout solenoid when going in reverse with the disc brakes.
Old 08-25-2009, 08:39 AM   #6
tim brown's Avatar
us1 , thats it , I was wondering if that was an option . I don't want to have to pull the coupler apart . thanks Tim , also I do have a reversing valve
Old 08-29-2009, 11:11 AM   #7
Powerquest 280 Silencer
Can you use the same actuator when switching to disc? I thought drum actuators wouldn't work with disc brakes?
MacGyver is offline   Reply With Quote
Old 08-29-2009, 02:04 PM   #8
tim brown's Avatar
yes you can , but you need to remove the residual valve in the master cylinder or poke a hole in it to let off the presure off the disc brakes , so I am told . Tim
Trackbacks are Off
Refbacks are Off
Search Engine Optimization by vBSEO 3.2.0
