Go Back   Offshoreonly.com > Technical > Do It Yourself, Boating on a Budget
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 09-18-2009, 02:58 PM   #11
Beak botr
88Fount33's Avatar
1988 Fountain 8.8
Was told that if my engines had any time in salt that converting to closed loop was no go, the salt in the iron would come out and turn the antifreeze/coolant into goo.
Anyone have experience with old iron and new conversion. Even with new block and intake, old heads would be too much salt iron I was told.
88Fount33 is offline   Reply With Quote
Old 09-21-2009, 09:02 AM   #12
faj
Quote:
Sounds like BS.
I'd be sure to give the engine a good fresh water flush before adding the anti-freeze just to be safe though
faj is offline   Reply With Quote
Sponsored Links
Old 09-21-2009, 09:20 AM   #13
Beak botr
88Fount33's Avatar
1988 Fountain 8.8
Kinda sounded like BS also, but it was a supplier of High HP fresh water cooling systems that told me no go, wouldn't sell it for my application (550 HP 540 CI). So I went Raw Water Cooled.
Last edited by 88Fount33; 09-21-2009 at 09:21 AM. Reason: early in the morning for typing.
Old 09-22-2009, 10:51 AM   #14
Charter Member #232
Audiofn's Avatar
1979 Formula 302
If you have rust in the engines and you swap over what will often times happen is the rust will clog up the exchanger. It can require you to flush the exchanger out a number of times before it will start to run correctly
Jon
God is my Co-Pilot..... but I hit a mountain and had to eat him.
Audiofn is offline   Reply With Quote
Trackbacks are Off
Refbacks are Off
Search Engine Optimization by vBSEO 3.2.0
