Go Back   Offshoreonly.com > Technical > Do It Yourself, Boating on a Budget
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 09-17-2009, 09:50 PM   #1
1981 Cigarette Mistress 33
Anyone have (4) TRW ZL 2399F pistons
I trashed a motor and need 4 pistons they are stamped #14097021. One of the members told me they are TRW ZL2399F's. I need four new pistons and one new rod.
OhioRiverCigarett is offline   Reply With Quote
Old 09-18-2009, 01:23 AM   #2
83' Nordic 23' Viking 505 BBC TRS Drive
Summit Racing has them.
http://www.summitracing.com/parts/TR...n/?prefilter=1
Exactly what motor is it? This piston is STD. bore size. If you damaged the cylinder walls any you will need to go with a over bore.There for you would need a full set. You could probably buy 1 rod at a chevy dealer.Most places only sell sets.
picklenjim is offline   Reply With Quote
Sponsored Links
Old 09-18-2009, 10:29 PM   #3
The L2399F uses a different oil ring than the 14097021. The 14097021 uses a low tension oil ring. Better off to replace your pistons with the same part number, or a whole set of the L2399F's, or you'll be goofed up when it comes to getting rings. L2399F is a Speed Pro number (used to be TRW), the "Z" in front of the part number is only a Summit Racing thing. I have at least a couple full sets of GM #3999295 (std. bore), which is the part number which is identical to the L2399F. I'm sure I have a rod too... 7/16" bolts in the rod?
PM me, or email jebcoent1@aol.com
cubicinches is offline   Reply With Quote
Trackbacks are Off
Refbacks are Off
Search Engine Optimization by vBSEO 3.2.0
