Go Back   Offshoreonly.com > Technical > Do It Yourself, Boating on a Budget
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 09-19-2009, 02:23 PM   #1
1981 Cigarette Mistress 33
Fluid Harmonic Dampners
How many people are running fluid harmonic dampners? I was running the OEM rubber dampner and I have been wondering if the fluid dampners are needed? I don't want to waste money.
Thoughts.
OhioRiverCigarett is offline   Reply With Quote
Old 09-19-2009, 03:06 PM   #2
sometimes over a long period of time the fluid can actually start to harden up
Ive used them in the past on some drag car motors but Im not crazy about them
what kind of motor are you putting it on,
if its a kind of mild motor (under 800hp) I would just run the pioneer balancer they make a regular one and an HD one,
I forget the part number off the top of my head but I usually go with the HD ones on mild type build stuff
they work great and are affordable (usually around $100-$125)
cbellamore is offline   Reply With Quote
Sponsored Links
Old 09-19-2009, 06:11 PM   #3
Rob
Strip Poker 388's Avatar
Hustler 388
cbellamore same as me,Mine came with the drag car.its about 11 years old.I would not buy it over,ATI first.Beawere of the cheap imports.
Now in a marine BBC I heard from a few engine builders the stock one is pretty good.I ran the stock on my 500efi 3 years and 2 years with the whipple.The only reason I change one had a little bit of rubber pinching out about .200. then bought these
http://www.offshoreonly.com/forums/g...fluidampr.html
http://www.offshoreonly.com/forums/g...amper-bbc.html
Strip Poker 388 is offline   Reply With Quote
Trackbacks are Off
Refbacks are Off
Search Engine Optimization by vBSEO 3.2.0
