While replacing manifold on starboard side i removed raw water drain attached to back of water pump. When i went to replace i noticed it had been on wrong. The main water inlet hose from transom 1.25 was on the outlet side of drain that feeds port side and hose from port side feed was attached to bottom main inlet feed for water pump. i pulled up Schematic to verify and it was wrong. The inlet hose should be 1.5 inch and current 1.25 hose will not fit to correct. If i switch to new 1.5 hose i doubt it will tighten down enough on transom inlet that is 1.25.
How can i fix this? What im thinking is to splice in a new piece of 1.5 with a barbed reducer 1.5 to 1.25. I'm figuring when repower was done they used original hose from 454 and 496 uses a larger diameter hose 1.5. I do not want to pull motor to change transom fitting.
Hose 5 and 15 reversed in first diagram.
