Go Back   Offshoreonly.com > Technical > Do It Yourself, Boating on a Budget
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 09-23-2009, 11:21 AM   #1
baja_brian's Avatar
25 Baja Outlaw
MDS Ignition
I know this is a little controversial, but is the MSD marine ignition set up worth the hassle. I have heard alot about keeping a spare msd box (since they like to go out). What about the ignition coil. Is it worth staying with the stock merc coil? I can understand a little improvement on paper, but will I see anything on the water. Is it worth putting on or not?
baja_brian is offline   Reply With Quote
Old 09-23-2009, 01:54 PM   #2
32 Active Thunder
I thought an MSD coil would be better on my 525SC. No difference and the MSD only lasted 2 seasons. I put a 10+ year old merc coil back on and it was fine.
I would just look for a V8-HP ignititon module for what you have.
Griff is online now   Reply With Quote
Sponsored Links
Old 09-25-2009, 02:15 AM   #3
32 Active Thunder
Disregard the V8-HP module suggestion since you have a TB V and MPI engine. I would just leave it alone or work with somebody on recalibrating the ECM and adjusting the timing curve.
Old 09-25-2009, 10:24 AM   #4
I haven't ordered one recently, but I understand that S&S (bought crane cams' assets) has the ignition / electronics products (including hi-6m ignition) and motorcycle valve train products back on line.
I like them a lot better than an msd set-up if you're going that kind of route. The last suggestion is probably the best...
wtfo is offline   Reply With Quote
Old 09-25-2009, 04:37 PM   #5
baja_brian's Avatar
25 Baja Outlaw
That I am not sure about Crane, I am about to give up on them. I am also thinking about scratching the the whole MPI set up and go carbed. I think I can add more hp going old school.
Old 09-25-2009, 09:18 PM   #6
getrdunn's Avatar
78 Spectra
i was facing similar to the same thing recently and just ended up going with the stock set up in my 496's. i have read way to many threads on failures with all the other types of ignitions on the market. i've ran stock TB's with up to 675 hp with no problems. on the other hand i never really did comparisons with other ignitions to know if one was better than the other however the stock ignition has always been very reliable.
getrdunn is offline   Reply With Quote
Old 09-25-2009, 10:32 PM   #7
http://69.20.53.62/
s&s is a decent outfit. I've bought bike parts from them for years and am fixin to order a new ignition...
Trackbacks are Off
Refbacks are Off
Search Engine Optimization by vBSEO 3.2.0
