Go Back   Offshoreonly.com > Technical > Do It Yourself, Boating on a Budget
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 09-26-2009, 02:47 AM   #1
sleek1
sleek1's Avatar
2001 Formula Fastech 353
Water leaking at transom/Latham fittings
I have water leaking around my Latham thru hull fittings (T fittings) on my transom. I want to take them off and reseal the contact points. What do I use to seal the thru hull area? Also my manual says to use Quicksilver power steering fluid, yet I hear guys running ATF in their systems... wich is correct?
sleek1 is offline   Reply With Quote
Old 09-26-2009, 01:54 PM   #2
32 Active Thunder
For Latham Hyd steering, use ATF. I would seal the holes with 3M 4200.
Griff is offline   Reply With Quote
Sponsored Links
Old 09-27-2009, 05:23 PM   #3
sleek1
sleek1's Avatar
Griff, thanks for the reply. Is ATF compatible with the Quicksilver PS fluid or do I need to drain and flush then put ATF in? If I need to remove the fittings in the future, will that be a problem with 4200? I not very familiar with that compound ( is it permanent?).
Old 09-28-2009, 12:55 AM   #4
32 Active Thunder
4200 has half the holding power of 5200. I would not think you would have a problem getting the fittings out if needed later. If you already have the QS PS fluid in there, then I'd probably just keep running that, but it should be fine if you mix in ATF. Most hyd steering manufacturers say to use ATF.
Old 09-28-2009, 02:25 PM   #5
Just a squirrel...
c_deezy's Avatar
88 240 with a new lease on life
We put ours in with 5200. But we don't plan on ever taking them out hopefully, hindsight now, 4200 may be a better option in case you strip a thead out on the fitting and need to replace it for some reason. Ideally you would want to clean out all of the previous sealant/adhesive from the holes, seal the holes with epoxy then reassemble.
c_deezy is offline   Reply With Quote
Old 09-30-2009, 07:26 PM   #6
sleek1
sleek1's Avatar
Thanks guys, I dropped the boat off at my mechanic's shop. I told him to reseal the fitting, drain the steering and put in ATF, also to change the filter. I need to get one more good trip to the lake before the water gets too cold.
Trackbacks are Off
Refbacks are Off
Search Engine Optimization by vBSEO 3.2.0
