Go Back   Offshoreonly.com > Technical > Do It Yourself, Boating on a Budget
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 09-30-2009, 12:47 PM   #1
89 Sea Ray Pachanga 32
Aluminum thermostat housing?
I am rebuilding a pair of 7.4 Merc's. I am basically throwing a 300 lb person off the aft of my boat by swapping some of the cast iron parts out for aluminum. Namely the exhaust manifolds (60 lbs each x4) and intake manifolds (guessing at least 20 lbs each X2) water pumps, and a few other small things... That being said, does anyone make an aluminum thermostat housing? I really don't want to bolt this heavy ass cast thing onto my nice new air gap intake. I have found a couple SS ones out there - look nice but expensive and still heavy...
Thanks!
spunner is offline   Reply With Quote
Old 10-01-2009, 10:44 AM   #2
1BIGJIM's Avatar
Location: Omaha, Nebraska. Boat on the Mighty Mo! Longest river in the USA!
Pachanga-27 Twin 502s
Since you are throwing everything overboard, get rid of the water pump also and go to a nice stainless cross over setup. Looks nice and it might save you 2 lbs.
1BIGJIM is offline   Reply With Quote
Sponsored Links
Old 10-01-2009, 10:52 AM   #3
Agreed, here you go.
http://www.rexmar.com/page161.html
Quote:
rdoactive is offline   Reply With Quote
Old 10-01-2009, 11:54 AM   #4
I was headed down that road already! However, the one thing I still do not understand is from what I am reading, it gets rid of the belt driven waterpump... but uses some sea pump or something - that is belt driven??? Not getting it... Wouldn't you use some inline electric pump or something? I am going crossover, is there any images of a mark iv with the setup on it anywhere? I would like to see what it is gonna look like
Old 10-01-2009, 04:05 PM   #5
Offshoreonly Advertiser
DiamondPerformance's Avatar
We sell a nice Stainless Steel replacement Housing.
www.diamondperformanceparts.com
diamondperformance@verizon.net
302-521-0123
The Best Parts & Service At The Best Price
DiamondPerformance is offline   Reply With Quote
Old 10-01-2009, 07:30 PM   #6
blue thunder's Avatar
330 Carver 30' Scarab Panther 17' ProV Lund
Quote:
You already have a belt driven sea pump. You just get rid of the circ pump and use the sea pump 100%.
blue thunder is offline   Reply With Quote
Old 10-01-2009, 07:53 PM   #7
I don't have a sea pump, that was part of my confusion. I am running Alpha's. The new engines I am putting in are gonna be 450+ HP so may have to go with bravo's anyway... damn this is getting expensive...
Old 10-01-2009, 09:13 PM   #8
www.getworkgear.com
Eclipse 233 sbc 383 dry piped
Welcome to working on your own boat. I have a stainless crossover you can have if you switch to bravos. Its dimpled to fit around a procharger mounting bolt but you can't see it from above.
Sunshadow is offline   Reply With Quote
Trackbacks are Off
Refbacks are Off
Search Engine Optimization by vBSEO 3.2.0
