Help with starter wires!!! Pics attached
As many of you know I lost a starter at LC Poker Run...Well I had it replaced and last weekend it stopped working agan. Figured I just ot a junk starter and was goin to replace it again. Well when I started pulling it apart I noticed there is a loose wire
1) There is a yellow/red wire and a orange wiure attached that go to the fuse box on side of motor
2)The ground wire is attached
3) The constant ground is attached
4)There is a red wire that runs to the fuse box on top center of the motor that is not attached to anything.
this could be nothing but I am hoping the installer just put a nut on loose and this is my only problem. Check it out and let me know. Sorry for thecrappy pics but its tight space in there.
