Go Back   Offshoreonly.com > Technical > Do It Yourself, Boating on a Budget
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 10-08-2009, 08:03 PM   #11
blue thunder's Avatar
330 Carver 30' Scarab Panther 17' ProV Lund
You already have a more static compression. I think it is 8.7:1 if a mag engine. Thats a nice bump over the 525sc which I believe was 7:1. You need a v-6 tbolt module with only 14* total advance. The v-8 have about 24 degrees which in order to make it idle right would put the all in timing too high.
I run the mechanical block mounted fuel pump but you can do what ever works for you.
blue thunder is offline   Reply With Quote
Old 10-09-2009, 01:17 AM   #12
Which mechanical block mounted fuel pump do you use? The one that sits on top of the sea pump? Or am i thinking of something else?
Eclipse232 is offline   Reply With Quote
Sponsored Links
Old 10-09-2009, 12:34 PM   #13
I used holley pumps and they bolt to the block like a traditional bbc. The sea pump is on its own.
Old 10-09-2009, 02:50 PM   #14
32 Active Thunder
525SC has 7.5:1 CR and runs a 22* advance module with a total advance of 35*
454Mag has 8.75:1 CR and run a 24* advance module with total advance at 32*
The module curves are not very different. You could run the stock module as long as you can get the engine to idle with only 8* of initial timing. I would not run more than 32* total with the 8.75 CR. You will also need to run 93 octane fuel.
Griff is online now   Reply With Quote
Old 10-09-2009, 04:50 PM   #15
I know this is gonna sound stupid again but is there any option to either supercharge or procharge without running 93 octane? Also without changing that much timing?
Old 10-09-2009, 08:00 PM   #16
www.getworkgear.com
Eclipse 233 sbc 383 dry piped
Quote:
maybe you don't really want to mess with it?
Sunshadow is offline   Reply With Quote
Old 10-10-2009, 12:18 AM   #17
32 Active Thunder
High performance needs high octane to make HP safely and live, especially when supercharging. You may be able to get by with 91 octane with about 4lbs of boost max.
Pay close attention to the effective compression ratio chart with regard to running 92 octane. Holley says 12:1 max for 92 octane. I would say more like 11.5:1 for a marine engine.
http://www.holley.com/data/TechServi...ech%20Info.pdf
Old 10-10-2009, 10:36 AM   #18
One point worth mentioning on my setup is I get away with more because I have aluminum heads. More effective compression for sure. I have been at 12.7:1 for 2 yrs of hard running and now at 13.4:1. If you have iron heads follow the chart as the chart is based on iron heads.
Old 10-10-2009, 11:21 AM   #19
baja_brian's Avatar
25 Baja Outlaw
Nice thread. Since we are talking about prochargers, is there many objections to a Vortec supercharger vs a procharger. They appear to have the same dynamics and concepts.
On a marine application it is almost a must to go intercooled, correct?
baja_brian is offline   Reply With Quote
Old 10-10-2009, 07:02 PM   #20
Mine are not intercooled.
Trackbacks are Off
Refbacks are Off
Search Engine Optimization by vBSEO 3.2.0
