Go Back   Offshoreonly.com > Technical > Do It Yourself, Boating on a Budget
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 10-26-2009, 02:41 PM   #1
Fuelin Around
FuelinAround's Avatar
Sonic 31SS
Made a booboo while winterizing what would you do?
Well trying to winterize your boat and watch your 4 month old is evidentally to hard for me. Got the oil changed and everything drained yesterday and was going through clean up. Sprayed the motor down with degreaser and fired up the pressure washer. When I started spraying the port motor I noticed something move and immediately stopped (probably been spraying 5-10 seconds on front of motor towards the top. What was moving was the oil cap on the valve covers. I FORGOT TO PUT IT BACK ON. So I got fresh oil in it and its winterized and done. I dont think much if any water got it. Probably just overspray if any. What would you do? I left the cap off last night to see if it might evaporate some. Anyone have any suggestions? I will change the oil again in spring forsure.
*ISN'T IT FUNNY THAT WAR AND LOSS OF JOBS BUILT SOME OF OUR MOST BEAUITFUL LAKE REGIONS?*
FuelinAround is offline   Reply With Quote
Old 10-26-2009, 04:16 PM   #2
Geronimo36
Panther's Avatar
36' Apache
Personally, I wouldn't take a chance... I would run it one more time to burn off any moisture...
Better to be safe than sorry.
Geronimo!!~
Panther is offline   Reply With Quote
Sponsored Links
Old 10-26-2009, 07:05 PM   #3
24 Baja Outlaw SST, LOOKING for nice 29 Outlaw
I cant be SURE, but, I seem to remember seeing an additive that truckers use to absorb water out of oil in diesel engines, I am not sure how much water you injested, best to be safe as Panther stated, did you check the dipstick and see what the oil looked like? if its milky then you DEFINATELY should change it
Good Luck!
Michael
n20michael is offline   Reply With Quote
Old 10-26-2009, 10:03 PM   #4
Ginger or Mary Ann?
US1 Fountain's Avatar
1999 32 Fountain Fever, 1995 Baja 29' Cruiser
Remove the belt so the impellor doesn't turn, thus no need to have water going to the motor, and let it run just long enough to circulate the oil, then drain and change.
US1 Fountain is offline   Reply With Quote
Old 10-26-2009, 10:16 PM   #5
Forum Regulator
Sydwayz's Avatar
Active Thunder 37' & other Factory boats, 13' Mini Hawk
Quote:
I'd say that's a fair way to alleviate any issues. Good idea. If you have a serpentine belt, remember that the alternator will not be charging either. So you can't run it long & you will have to maintain the battery.
Brian T.
Active Thunder Factory Rep.
Web: ActiveThunderBoats.com
Email: brian(a)activethunderboats.com
Sydwayz is offline   Reply With Quote
Old 10-26-2009, 11:41 PM   #6
mike tkach's Avatar
31 american offshore,38 fountain fever
look inside the valvecover,if a small amount got in,you can remove the cover and dry the water out.
MIKE TKACH
mike tkach is offline   Reply With Quote
Old 10-27-2009, 08:52 AM   #7
Lakeside Restorations.com
Commercial Member
LAKESIDE RESTORATIONS's Avatar
You dont want water in there.. It is cheaper to waste another pack of oil than to have valvetrain work or more to possibly do in the spring. Jamie / Lakeside
www.LakesideRestorations.com 570-639-2628
We Make Fast Toys Faster, Cool Toys Cooler and Old Toys New!.. Performance, Custom & OEM Parts & much MORE![/CENTER]
LAKESIDE RESTORATIONS is offline   Reply With Quote
Old 10-27-2009, 03:17 PM   #8
32 Active Thunder
I would not use a pressure washer on an engine anyway. Bilge, yes, but not on the engine. Too many places that you don't want water to get in to.
Griff is offline   Reply With Quote
Old 10-27-2009, 03:26 PM   #9
1992 24' Baja Outlaw
DO NOT RUN IT!!!! Water will sink to the bottom of the oil pan under the oil if you dont run it and mix it all up. Drain off a little bit of oil into a cup or something small and see if any water comes out with it. If you just get a few drops or none at all then I would start it and burn it off. If you got a bunch of water into it, your life will be alot easier if you let it reach the pan and drain it out before starting.
OutlawMan is offline   Reply With Quote
Old 10-27-2009, 05:21 PM   #10
Fuelin Around
Sonic 31SS
Usually don;t have to use a power washer on the engine. If I have the motors pulled I will bag them like crazy and spray them down but someone sold me a busted oil drain pump. Damn thing built pressure then blew about a quart of dirty oil all over everything. Should have just kept the old one I had but I wanted the new shiney one lol. Got it working now. Going to check the oil tomorrow and see how it looks. If it looks ok I am going to run it and rewinterize the motors
Trackbacks are Off
Refbacks are Off
Search Engine Optimization by vBSEO 3.2.0
