Go Back   Offshoreonly.com > Technical > Do It Yourself, Boating on a Budget
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 11-12-2009, 04:58 PM   #1
Fountain 33 Executioner
Engines won't shut off ???
Carbed 502's. Had this problem for a while just happened one day. Even bought new alternators. They are Bosch internally regulated, just a single ignition wire to them. I tried running a globe inline and also tried one way diodes inline but still run on, unplug the alternators and they shut down. Any suggestions ???
thanks for the help.
Dan74 is offline   Reply With Quote
Old 11-12-2009, 07:55 PM   #2
Owner/Operator
ChristianGott's Avatar
1987 SUTPHEN RUMRUNNER
i had a 350 that would start itself...freaky! there was an undiscovered short in the wiring harness that occurred when the starter went south....maybe unplugging the alts just breaks the circuit...and the problem is elsewhere...starter/ignition?
"There are only two races on this planet-the intelligent and the stupid."
ChristianGott is online now   Reply With Quote
Sponsored Links
Old 11-16-2009, 12:29 PM   #3
1987 chriscraft Scorpion 230
I had the same problem when I went from motorola to single wire ac delco. you have to run the wire direct to the battery, as most alternators other than the delco incorporate a wire to excite the field on the alternator
doggiedave is offline   Reply With Quote
Old 11-16-2009, 10:20 PM   #4
87cafe
mhydro4u@aol.com's Avatar
1987 cigarette cafe racer
maby a bad switch!
mhydro4u@aol.com is offline   Reply With Quote
Old 11-17-2009, 11:34 AM   #5
1996, Donzi, 22 Classic 502
Quote:
That is so funny, the engine would actually start itself?
Pismo10 is offline   Reply With Quote
Old 11-17-2009, 12:25 PM   #6
Quote:
i agree with dave did the same those motorola are junk
bajabob is offline   Reply With Quote
Old 11-17-2009, 05:52 PM   #7
Owner/Operator
hey pismo....
yeah, it would turn and turn....but, when warmed up...fire!
real wierd...i'm loading the boat at the ramp (walking to get the truck), and i hear another loud boat...so i go to check it out and realize it's MY boat!...unless boats can be haunted, it's the strangest thing i've ever seen....
c
Old 11-17-2009, 07:50 PM   #8
1992 24' Baja Outlaw
If it is a one wire hookup you must connect it straight to the battery with appropriate sized wire. Right now you are charging through your ignition system. While charging, you will always have power to the ignition with your current setup.
OutlawMan is offline   Reply With Quote
Old 11-17-2009, 11:46 PM   #9
1991 cigarette 42' revolution with 3-750 hp hawks and ssm drives,2009/1979 cig 35' mistress [for sale]
were these originally 3-4 wire harnesses ,or were they allways 1 wire set-ups ?
dmaxx3500 is offline   Reply With Quote
Old 11-18-2009, 04:02 AM   #10
Quote:
Since I have had the boat (10 years) they were 1 wire jobs for exciting. At the moment charges through the factory harness /ignition system?. I will run a new separate wire to the battery direct I should done this before !!!
thanks for all the help & coments !!!
Trackbacks are Off
Refbacks are Off
Search Engine Optimization by vBSEO 3.2.0
