Go Back   Offshoreonly.com > Technical > Do It Yourself, Boating on a Budget
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 11-14-2009, 06:24 PM   #1
24 Baja Outlaw SST, LOOKING for nice 29 Outlaw
Baja Stereo install/mounting question??
Hey Guys!
I am looking at upgrading the stereo in my 24ft Outlaw, there IS a system in it now, so, its pretty straightforward, but, I am not sure how to remove the existing amps from the bulkhead? [between the cabin/cockpit] the amps are mounted on the "drivers" side inside the cabin [where most people mount them] I cant get my hand "behind" the bulkead or between the cut out for the cabin door opening, so, I assume the actual panel in the cabin comes down?, any idea how?, there is an "arch" about 2 inches wide that mounts across the top of the bulkhead from side to side, it "appears" that this is what prevents the bulkhead panel from coming down, do I remove this?, how is it done?, I dont want to damage anything, or have it looked "butchered" when I am done, so, I would appreciate someone telling me the correct way to do it, Thanks in advance!
Michael
n20michael is offline   Reply With Quote
Old 11-15-2009, 06:12 PM   #2
Anyone?
Sponsored Links
Old 11-15-2009, 07:26 PM   #3
baja_brian's Avatar
25 Baja Outlaw
I am not sure abou the 24 Outlaw, I have the 25 Outlay and I can get to the bulkhead by removing the lower dash panel and the fuse box that is under the steeting wheel. I think the 24 might be diffrent but not for sure. Did you post anything in the Baja Form? Brian
baja_brian is offline   Reply With Quote
Old 11-15-2009, 09:54 PM   #4
Thanks, I dont think I can get access from there, but, will have another look, did post in the Baja forum, but, no luck yet, Thanks! for the reply!
Michael
Trackbacks are Off
Refbacks are Off
Search Engine Optimization by vBSEO 3.2.0
