Which ujoint removal and installation tool is used out there by fellow boaters?
I am removing the ujoints on my bravo one outdrvie and I wanted to know what the easiest tool out there was to work with. I found a kit at at harbor freight called 3-in-1 Ball Joint/U-Joint/C-Frame Press Service Kit and wanted to know if anyone has used this and what their thoughts on it are? Here is the linke below to the site so you can see exactly which one im talking about
http://www.harborfreight.com/3-in-1-...kit-38335.html
you might want to consider taking it to a shop with a press . I wouldn't think it would cost much more than the tool to get this done. frustration factor is worth a lot around my crib.
I use the hammer and punch method myself, but if you dont know how to do that method properly, I suggest taking it to a shop and having it pressed out! I agree with the frustration level!
