How To:  Rebuilding Merc Sea/Fuel Pump >
Old 05-23-2013, 03:57 PM
Great Post ROOKIE ,very informative and adding the oil drain valve is well worth the time .
PRIMECUT is offline
Old 05-24-2013, 01:09 AM
nice
Meshikinquah is offline
Old 06-18-2013, 11:05 AM
thanks this was very helpful to me today my fuel pump took out the bearing in the drive this weekend
jpthrill is offline
Old 06-20-2013, 09:33 PM
Rookie's Avatar
Received 1,206 Likes on 579 Posts
You're welcome. I'm glad it helped you out.
Rookie is offline
Old 07-01-2013, 09:06 AM
Ok I have a ? Is there a way to replace the cam that the fuel pump lever rides on? I think mine is worn out. I just replaced the fuel pump and I am not getting the psi at high rpm like on the other engine.
freekazoid is offline
Old 07-01-2013, 09:09 AM
Originally Posted by Griff
The only thing that expands, that I know of, in the cold is water/ice. Everything else shrinks.
You forgot nipples.
4bus is offline
Old 07-01-2013, 09:48 AM
Were doomed!
Wally's Avatar
Yes, you would need to replace the entire shaft of the pump....the cam is all one piece... you can look it up on mercruiserparts.com
heres a quick search I did for a 500efi model.. http://www.mercruiserparts.com/Show_...+Pump+Assembly
your looking for part#12 in this display...but that's not to say its the one you need...
-Wally
Wally is offline
Old 07-01-2013, 11:02 AM
Sweet thanks Wally
Old 04-08-2014, 11:46 AM
Hey Rookie and Mild Thunder did you ever use the new Airtex Replacement Pump Part # 60932.....sounds like everyone is saying Airtex makes the pump for Merc. etc.
SC288 is offline
Old 04-08-2014, 12:34 PM
Hey Mike. I've never used those pumps. My engines are the old Mark IV's. I run the self regulated block mounted 6 valve mechanical pumps. I love them. No regulator needed, and will support a ton of power. Same pumps merc used on the 900sc and 1000sc.
For some reason in my head, I thought the merc pumps were made by carter? I honestly don't know. I do know, I used an Airtex pump in my dually, (in tank electric), and it lasted about a week. Switched to a Delphi pump, no issues.
CV products makes a bad azz pump for the seapump deal. Quite expensive though!!
MILD THUNDER is offline
