Another X question
#53
Geronimo36
It's easy to do but hard to explain accurately..
#54
Put the tool in the coupler half way, then tap the tool, up/down/left/right until the bearing lines up with the coupler. The gimbal bearing has quite a bit of movement in any direction. Then insert the tool the rest of the way into the coupler to check alignment.
#55
LOL
I went by the local shop talked to the guys. Now I understand what you two were saying. Didn't realize the gimbal bearing could be off. I've only aligned a motor once before & the tool slide right into the coupler so this wasn't an issue. I'll try it again. Thanks
#56
Very helpful thread! Have you (or anyone) had any issues with the aluminum bar stock you used to space up your engine mounts? I always wondered if they would have problems if you came off a good sized wave not quite straight or something.
Thx!
Thx!
#59
I’ve put roughly 70hrs on the boat since this mod & the bar stock spacers are rock solid.
My results are similar to Jeff’s in post #3. 3 blade props are worthless & 4 blade props are fast but blow out in tight turns. 5 blade props help a lot but you lose some of the top end speed advantage. I put in a .5” drive spacer last week but haven’t run the boat yet. Ideally I’d like to go back to the 4 blades if I can keep it hooked up in tight turns for water sports.
