Register
If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Follow us on Facebook Follow us on Twitter
Results 1 to 7 of 7
  1. #1
    Platinum Member Platinum Member frickstyle's Avatar
    My Boats:
    1990 Top Gun, Pursuit 3370
    Join Date
    Nov 2007
    Location
    Cleveland, Ohio
    Posts
    2,534
    Flipping/Turning over a boat/hull
    I would like to flip my boat/hull over in order to straighten out the bottom, fix gouges, and paint it. Can anyone post pics of what they used to turn over their boat? I can make something to hold it, just wanted to see what others have used. Everything will be stripped out, almost to the bare hull. Hell, even turning just 90 degrees would make this job much easier (thinking similar to a car rotisserie for frame off restos)....
    Can you thru bolt a pinion to the outdrive mounting holes and make something to support the front section of the hull???
    "America is all about speed. Hot, nasty, bada$$ speed." -Eleanor Roosevelt
  2. #2
    Gold Member Gold Member c_deezy's Avatar
    My Boats:
    88 240 with a new lease on life
    Join Date
    Aug 2006
    Location
    Ontario, OH
    Posts
    2,432
    Here is how somebody did it:
    Bluprinting My Hull and...........
    You shouldn't need to flip it completely over, but being able to rotate it to do one side of the botttom at a time would definitely make things easier. Some big foam blocks would work good.
  3. #3
    Ginger or Mary Ann? Charter Member US1 Fountain's Avatar
    Join Date
    Oct 2000
    Location
    Lafayette, IN
    Posts
    10,831
    My brother and myself did it on his 23' Glastron. Not the heaviest by any means. Used a long steel pipe going into the bilge, fastened inside to the engine mounts and at the transom with plates bolted to the holes. With a larger pipe that slid over that pipe acting as a bearing, used a chain and chain hoist wrapped around the larger pipe section and connected to an over head beam. At front, used an engine hoist connected to a strap looped thru the bow eye to keep it from sliding forward. We ended up having to run a couple of ropes from the strap to a point rearward, to keep the strap from slipping forward over the nose as we rolled it over. Very surprised at the amount of force required to get it just vertically. A lot of weight in the bottom keeping it bottom heavy.We ended up using a come-along on one of the rear u-bolts to help pull that side up to flip it. Just go slow and watch whats going on. The size/weight of your boat may require more HD equipment than the engine hoist we were able to use.
  4. #4
    Registered VIP Member
    My Boats:
    Sonic 31SS
    Join Date
    Jul 2009
    Location
    Owensboro, KY
    Posts
    1,571
    We painted a guys here locally by raising the front. He had 12ft ceilings I believe. We took the boat off the trailer and set the back on tires then lifted the bow way up in the air so it was at an angle
  5. #5
    My Boats:
    Join Date
    Nov 2007
    Location
    Cleveland, Ohio
    Posts
    2,534
    Thanks for all the info guys. I agree, I'm not going to turn it completely over, even 45-70 degrees makes it more accessible. I just have to figure out how to support and turn the front, the back is easy. What about some heavy timbers cut to the profile of the hull made as a half cradle?
    The hard part is getting it to "roll" in a controlled manner.
  6. #6
    My Boats:
    1997 fountain fever 32
    Join Date
    May 2006
    Location
    Jackson, Mississippi
    Posts
    448
    Might want to drain/siphon your fuel tank to prevent flowing out the vent.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
OSO Sponsor
OSO Advertisers
OSO Directory
Powered by vBulletin® Version 4.2.0
Copyright © 2017 vBulletin Solutions, Inc. All rights reserved.
Search Engine Optimization by vBSEO 3.6.1
Original Poster In Postbit provided by Original Poster In Postbit v1.0.0 (Free) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting.
