carb gurus
carb gurus
have a stock 502 stock cam vic jr intake hp 500 heads and a holley 750 with power valve in primary and 75 jets and no power valve in secondary with 85 jets. Is this enuff carb, or do i need a 800 cfm or can i rejet ???
thanks
dan
thanks
dan
Didn't the 502/500 hp come with the 800 cfm 9022. There a good Carb. Even if you do faten up the jetting on that 750 I would be extremely careful. Personally I wouldn't even run it cause it's so dam hard to stay out of the throttles. Be sure and do pleny of plug checks if you do run it. If you need to go over 4 to 6 jet sizes go bigger carb.
Which holley 750 is it? you can get it jetted right, but it will take a little more than standard jetting (ie maybe change air bleeds, drill the pvcr out some in the primary metering blocks, etc...). Note that you can swap out the body for a proform body to make it an 800.... IF it's a standard 4150 and the base plate and shafts, etc.. are in good shape, that would be another option. Just some thoughts
