twin outboard battery wiring diagram
DynoJet, thanks for the feedback but couple questions. How does the stereo bank get charged? Also the motor portion is a little sketchy it appears the batteries are attached to the output and position 2 of the left switch and the output and position one of the right switch. Then it looks like port motor is connected to position one of the left switch and the strbd motor is connected to position 2 of the right switch. That doesn't make any sense to me...
Each engine has its own switch, where both batteries are connected. On the back of the switch you have batt 1 and batt 2 inputs, then Output to the engine. This is so you can turn the batts off to that motor, run the motor off batt 1, batt 2 or both at the same time (parallel the batts to the engine).
To me if you were to use two switches then the port motor would be connected to the output of the left switch a battery would be connected to position 1 and position 2 would be tied to position two of the right switch. Then the strbd motor would be connected to the output of the right switch and another battery would go to position 1.
Assuming that is correct and you could run the boat with both switches in the 1+2 position then I don't see a reason you couldn't just use a single switch with the output connected to both motors and a single battery on position one and a bank of 2 or more batteries in parallel connected to position 2. Is there a reason I can't do it that way? The only thing I can think of is that the alternators may not like working together.
