alpha one gimbal ring help!
i have a 1989 formula that i am servicing this year and im now in a bit of a jam trying to salvage my summer...the boat has an alpha one gen one drive...the motor is currently out i have a replacement ordered. I had some play..about an inch in my drive in the gimbal ring...i replaced the square steering shaft a few years ago and wanted to tighten up the gimbal ring pinch bolts...well one side tighten up nice and on the other side it snapped fml. about half the bolt is in there..so ive tried hammering it through...its seized ive tried heating but can't get it to budge....should i try drilling it...i ordered new hardware but can't get the old bolt out...i don't have any alpha special tools so im trying to avoid pulling the gimbal ring...i guess with the motor out i might have no choice. can someone tell me what to do to get this bolt out or can someone tell me what procedure to take to dissasemble this thing...i appreciate all your help..
-Harry
-Harry
try a left hand drill after soaking it in penetrating oil. If that doesn't work, drill and tap is about your only option
thats the problem...it is through bolted there is a nut on the back i can't get off either...im worried if i drill it that it will break loose...there isn't enough room for the bolt to go out the back of the hole...if you know what i mean. any recommendations on drill bits?
Just went through this myself. Had some play in the gimble ring, tried to tighten the bolt and it snapped. I heated and sprayed with penetrating oil over and over and eventually was able to beat the old bolt out.
Edit.. Actually Im thinking of the steering shaft bolt not the 2 gimble pinch bolts.
RIPSTA Racing Team
I'm wondering even if you get the bolt out if just replacing the hardware will take that much slop out of the steering? Personally since the engines out already, I would have to consider replacing the Alpha with a Bravo. Pretty easy to find a good take out cheap to replace it with and a simple swap.
1 Post
Fixx
hold pressure on the vice grip to keep it from turning then when the bigger bit gets to the end all you will have left is the nut and it will drop out..
thanks for the replies guys...going to pick up some bits today...the play isn't that bad at all i had just said to myself rather than tighten the old bolts and snap them let me pick up some new bolts and bring them to factory specs...thinking i was doing the right thing...then snap wtf....gotta love boating
ps...the play was only an inch at the tip of the drive...so i think the new bolts will help...if i can only get this damn thing out
Formula I would take Fire's advice and replace it. At a minimum do not put the motor back in until you get this resolved or you will really be kicking yourself in the ass later..
Chris
Chris
