Replacing obsolete fuel injectors
This forum totally rocks.
Call Linder Tech in Indy they are the injector guru's and will be able to get you a set of injectors no problem. 888-809-3835 http://www.lindertech.com/index.html
I.e. the regular Bosch Injector design II pintle type at @ 24lbs/hr flow.
Used by many makes.. Ford Motorsport for the 5.0 Mustang GT usually are the cheapest.
http://www.justfuelinjectors.com/ser...flowchart/Page
The exact OEM Bosch replacement is pretty damn expensive, at around $140/each. But now that I have the stats, I can find something that matches I think.
Can I replace the pintle type with a four hole type? Does the lb/hr have to match the original exactly, or can I change a little? What about the PSI rating? There are other much more affordable injectors that Bosch makes that are similar, but not exactly the same. Most are the four hole type.
Oh man that is awesome. I thought I was going to have to replace the port fuel pump, and I might have to replace the starboard one. I was trying to figure out the replacement and I had no idea what to look for. After I read this, I looked at the fuel pump online for a 1991 Porcshe and yup, it's identical. If I have to replace that starboard pump for some reason, can I just use this same fuel pump? Are they any different for marine applications? Doesn't seem like it would be, but I don't know.
I've seen these used on F1 engine dynos and injector test benches as well.
I run one on my Donzi.
Jeff
