Register
If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Follow us on Facebook Follow us on Twitter
Results 1 to 3 of 3
  1. #1
    Registered Gold Member
    My Boats:
    1991 26' IMP - Twin 350s
    Join Date
    May 2011
    Location
    Austin, Texas
    Posts
    94
    Question Gimbal housing removal - cutting a hole?
    Greetings,
    I've got a 1991 Bravo one. I was tightening the nut over the plate that holds the two trim sending unit wires into the gimbal housing. The stud snapped off. I was stupidly following the torque specs sent with the unit - which were wrong for my year model.
    Anyway, I'm trying to extract the snapped off stud. I can't get the extracting tool to thread because that stud is just up enough behind the gimbal ring to prevent getting it out. So I've got to remove the gimbal ring. I've seen some methods on the internet where guys cut an access hole in the side and on the back of the housing. This seems rather drastic to me. I guess if you have the motor installed, you have to do this. However, my starboard motor is out, I had it rebuilt. So it seems to me the best solution would be to remove the transom plate and just pull the entire assembly from the transom. Since the motor is out I can access it. Am I right about this? Or is there some reason I shouldn't remove that assembly from the transom?
    I'm a newbie at this. Since the boat is a 1991, this rebuild has turned into a major project. Every turn has required more and more parts (it's starting to make me nuts). Was just going to replace bellows; then I needed a new oil line, then a new shift cable, then needed trim sending wires, then accidentally snapped off the stud for the sending wire plate.
    Recommendations?
    Thanks!
    Stan
  2. #2
    Charter Member #232 Charter Member Audiofn's Avatar
    My Boats:
    1979 Formula 302, 88 Formula 311, 81 Donzi 18 2+3 with 454
    Join Date
    Oct 2000
    Location
    Manchester, MA USA
    Posts
    18,005
    Have you tried using a punch to get a centering hole then drill it out and then use a back out tool?
    God is my Co-Pilot..... but I hit a mountain and had to eat him.
  3. #3
    My Boats:
    Join Date
    May 2011
    Location
    Austin, Texas
    Posts
    94
    Yes, using an extension, and a lot of patience, I got a centering hole drilled in the stud. The problem is that there isn't enough room for a back-out tool. The stud is too far up inside the housing. I can't get the tool threaded because it's at an angle. The gimbal ring is in the way.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Powered by vBulletin® Version 4.2.0
Copyright © 2013 vBulletin Solutions, Inc. All rights reserved.
Search Engine Optimization by vBSEO 3.6.1
