Register
If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Follow us on Facebook Follow us on Twitter
Results 1 to 5 of 5
  1. #1
    My Boats:
    1987 baja 240 sport
    Join Date
    Sep 2011
    Location
    buddlake, nj
    Posts
    8
    bell housing for new motor
    hi, guys im new to boating but not to mechanal stuff so ill give this a try im wanting to install a a lq4 6.0 im my baja im place for the blown up big block i got with the boat could someone tell me what bell housing flywheel and coupler to buy to hook up to my bravo 1 thanks
  2. #2
    Pirate of the Chesapeake Gold Member Fenderjack's Avatar
    My Boats:
    32 Fountain Fever FOR SALE /202 Chris Stinger/ 33 Fountain under construction
    Join Date
    Aug 2006
    Location
    North Point Creek, Md.
    Posts
    3,355
    belhousings
    Quote Originally Posted by stroker331 View Post
    Belhousing is the same as a regular chev bit your block uses metric bolts.You need a stick flywheel for your motor and just use a standard merc bravo coupler,You may have to have your stick flywheel drilled to match it . Not sure if they are drilled the same.You also will need the kit so you can use the standard chev side motor mounts,summit end jegs sell them.Make sure you can get exhaust manifolds first I here they are big $$$$$ JOHN SR
  3. #3
    My Boats:
    1987 baja 240 sport
    Join Date
    Sep 2011
    Location
    buddlake, nj
    Posts
    8
    thank you im making the exhaust myself so thats not a problem it was just coupling the lq4 to the bravo. What do you think i should do for cooling raw water or seperate closed cooling remember this engine is all iron and im not looking to do aluminum heads or anything in the future.
  4. #4
    My Boats:
    Join Date
    Aug 2006
    Location
    Posts
    3,355
    YOU are going to run all raw water cooling is that what you are saying.If so I think you have serpentine belts. If so get a later modal merc sea pump that is serpentine belt and make a bracket.And I think that block uses reverse flow cooling but I'm not sure on that.You could run a crank drive volvo type pump but I don't think the balancer on them motors has bolt holes in the like a reg chev. JOHN SR
  5. #5
    My Boats:
    1987 baja 240 sport
    Join Date
    Sep 2011
    Location
    buddlake, nj
    Posts
    8
    how about a serpentine drive volvo penta pump and make a bracket for that. Should i also put a sea strainer on also my boat never came with one i thought it would be a good idea?
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Powered by vBulletin® Version 4.2.0
Copyright © 2013 vBulletin Solutions, Inc. All rights reserved.
Search Engine Optimization by vBSEO 3.6.1
