Register
If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Follow us on Facebook Follow us on Twitter
Results 1 to 2 of 2
  1. #1
    My Boats:
    96, Formula, 382 SR1
    Join Date
    Sep 2006
    Location
    LaCrosse, WI
    Posts
    111
    Opinions wanted on HP500 carb cam and OE rollers
    As some of you know, I have 540's with 9.2:1 CR, 900 cfm carbs, and Merlin intakes with Profiler heads and a Comp cam with .640 lift and 300 plus duration. The issue I have is terrible idle quality. I am going to sacrifice some high RPM power for a better low RPM behavior. I am considering putting a crane 169611 cam (the HP500 carb cam) at .576 and .598 lift and 284 /292 @ .004".
    The original hp500's that came in the boat idled great and had pretty decent power. I do not run the 540's much past 5200 rpm anyway. What do yoy guys think.
    Also- stock GenVI rollers. Reccomendations are not to exceed .570 lift. I am running them with my .640" cam with out a problem. Am I lucky, or would it be OK to run the HP500 cam with OE rollers.
  2. #2
    My Boats:
    2000 eli.
    Join Date
    Feb 2005
    Location
    cincinnati,oh.
    Posts
    169
    585-654-8583 Ask for Bob Madera he will fix you up.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Powered by vBulletin® Version 4.2.0
Copyright © 2013 vBulletin Solutions, Inc. All rights reserved.
Search Engine Optimization by vBSEO 3.6.1
