Register
If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Follow us on Facebook Follow us on Twitter
Results 1 to 5 of 5
  1. #1
    Blown Formula blown formula's Avatar
    My Boats:
    312 Formula & 31SS Sonic
    Join Date
    Feb 2001
    Location
    Lake Eufaula, Ok.
    Posts
    1,506
    Exclamation Swivel pin clearance/tolerance question???
    Does anyone know the bushing to swivel pin clearance or tolerance? Can anyone measure a good or new swivel pin so I will know if I need to replace one or both of my s. pins......
    both have different dimensions by a small amount, but how much is too much??? New pins are expensive, so I do not want to replace them if not needed.
    Thanks in advance!!
    Last edited by blown formula; 03-06-2012 at 06:46 PM. Reason: to subscribe to post
  2. #2
    Platinum Member Platinum Member picklenjim's Avatar
    My Boats:
    83' Nordic 23' Viking 505 BBC TRS Drive
    Join Date
    Mar 2009
    Location
    OFallon,Mo.
    Posts
    1,431
    How about a hint. What set up is it.
  3. #3
    My Boats:
    Join Date
    Feb 2001
    Location
    Lake Eufaula, Ok.
    Posts
    1,506
    Bravo 1 swivel pin (gimble ring swivel pin) ... Sorry, but that is the only swivel pin on a boat I was aware of..... Sonic 30SS. My bad!
  4. #4
    My Boats:
    Join Date
    Feb 2001
    Location
    Lake Eufaula, Ok.
    Posts
    1,506
    Well, I don't know if anyone else is interested....
    but the stock swivel pin measures-
    bushing surface 1.122"
    square part for the gimble is 1.375"
  5. #5
    Platinum Member Platinum Member MILD THUNDER's Avatar
    My Boats:
    1990 38 Fever SSM IV
    Join Date
    Jul 2004
    Location
    chicago
    Posts
    4,086
    Have you tried re-torquing them?? Most people never re-torque them as part of a maintance program. They get loose, then wear prematurely. I have been able to get them to tighten up a bit with a re-torque to spec.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Powered by vBulletin® Version 4.2.0
Copyright © 2013 vBulletin Solutions, Inc. All rights reserved.
Search Engine Optimization by vBSEO 3.6.1
