HELP! EMI Installation
Anyone ever run into this problem? EMI Manifold on port side of Gen IV 454 Mag. Manifold will not clear pressure line coming out of back of power steering pump. What did you do to resolve this issue?
https://www.google.com/search?rlz=1C...4d42831c954613
google banjo bolt. I saw a setup once the basically replaced the pressure line from the pump. I will dig into it a little more.
Many brake line components use banjo bolts.
1 Post
fixx
yep have done a few..you need to put a sharper bend in the 90* fitting,,almost 120* and it will fit..i ran the hose along the intake and valve cover and used a slightly shorter belt.
run the hose along side the valve cover and once you follow the curve on the front of the valve cover you will w\see wht i mean,the 90/120* part will be facing the towards the intake..leave the fitting loose and tighten the belt first then position the fitting and tighten it..
