Register
If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Follow us on Facebook Follow us on Twitter
Results 1 to 3 of 3
Thread: 454 heads 049
  1. #1
    Join Date
    Sep 2011
    Posts
    15
    454 heads 049
    does anyone have or know anyone with some good 454 heads? i found some 990s but heard the crack easy on a marine engine
  2. #2
    My Boats:
    1989, Pantera, 24, 454
    Join Date
    Jul 2010
    Location
    Deerfield BCH, FL
    Posts
    422
    I have stock 781s I'm not impressed w them but I've read good things, I should've done some flow work to them and maybe increase valve size bc I can't get 454 over 5200 rpm
  3. #3
    Platinum Member Platinum Member MILD THUNDER's Avatar
    My Boats:
    1990 38 Fever SSM IV
    Join Date
    Jul 2004
    Location
    chicago
    Posts
    4,066
    Quote Originally Posted by Smithelectric View Post
    990 heads were used on about a millon stock mercury engines. They are no more prone to cracking than any other iron gm head.
    My thoughts on heads are this.
    By the time you buy a set of used heads, buy new inconel and severe duty valves, have the heads magged, machined, valve jobs, new springs seals and guides installed, many times you aren't that far away from a set of superior aftermarket bolt on castings.
    Without knowing your combination, I can't suggest any heads, and if your running in salt, then youd prob wanna stick with iron heads. If so, the Dart 308 Iron Eagles would be a nice 454 head. If aluminum is a option, the dart 310 Pro 1 is a excellent choice, or the edelbrock marine rect ports. Price wise, its hard to beat the edelbrock marine aluminum heads.
    I believe the Dart Iron Eagle 308, is comparable cost wise to the Edelbrock marine Aluminum. Both have some advantages.
    The Darts have raised exhaust ports, cast iron is very durable, and in my opinion back to back would probably make a bit more power than the Edelbrocks due to the design. The dart 308 High velocity casting has been around a long time, and is a proven HP maker on a smaller big block like a 454.
    The edelbrocks, will be lighter, allow for a bit more compression, can be repaired more easily if something happens.
    One of the problems on a 454 bore size, is the compression. If you are running a flat top piston, or a dish, you will have less than optimal compression unless you plan to run a blower. With a 118CC chambered head, you are looking to be around 8.2-8.4, and with a GM dished, under 8:1. With small domes, like a 454 mag piston, you will be closer to 9:1.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Powered by vBulletin® Version 4.2.0
Copyright © 2013 vBulletin Solutions, Inc. All rights reserved.
Search Engine Optimization by vBSEO 3.6.1
