Gaffrig Mechanical Indicator Parts
I'm looking for where I can purchase the 1" black tubes w/red dots and 1" springs that go inside the tubes??? (4 position - 2 drives & 2 tabs 1995 version) I've had no luck thus far! I took this thing apart to put a red dot on one of the tubes and now I'm sorry I started this project! I have 10 hours in trying to line up the red dot tubes/springs with the slots and than bolt the cable tray to the 2 studs. The last time when I got the closest, the thing slipped and 2 tubes & springs flew out & missed my catch towel and now I can't find them. What is the trick to putting this thing back together?????
Livorsi, has pins and springs. The trick to getting them in!!!! Having access, undo the drive indicator push tubes and cables off of trim tabs. This will relieve some of the pressure on the cables. Its a pain either way you look at it, unless you can lift the panel up for access. If you have a pic of indicator it may help.
