Register
If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Follow us on Facebook Follow us on Twitter
Results 1 to 6 of 6
  1. #1
    My Boats:
    1979 Formula 233 Interceptor w/ twin 300hp 5.7l's
    Join Date
    Aug 2010
    Location
    Tacoma, WA
    Posts
    137
    I think I need a MacGyver trick here.
    Heres the deal. I heard a pretty signifigant tick on my starboard engine which I thought was a stuck valve, took the valve cover off and looked for the obvious. I then decided to take the easier route and pop of the exhaust elbow and riser hoping it was just a bad gasket. I replaced the gasket between the exhaust manifold and riser, and also the riser and elbow. Started it back up and bingo....no tick!
    Here the problem, in the process of doing this I damaged the gasket between the manifold and an adapter plate that sits between the riser and manifold. The manifold has an exit that is a square flange then the adapter changes it to a larger rectangular size which then mates with the riser.
    I have no idea how the adapter plate was held on, the two most forward bolts on the manifold line up with the adapter plate however the two rears do not. When I took it off I had to drill out some kid of threaded stud the previous owner used, but there was no head on it. If you look at the picture of the adapter installed that was before I drilled out the studs, as you can see no heads on the studs.
    Top of Manifold
    Bottom of adapter plate
    Adapter Installed
    Riser setup
  2. #2
    My Boats:
    Join Date
    Aug 2010
    Location
    Tacoma, WA
    Posts
    137
    No ideas of how to mount this adpater? What about using a liquid gasket material and threading in studs on one side with thread locker?
  3. #3
    VIP Member VIP Member The Buda's Avatar
    My Boats:
    93 Apache Warrior
    Join Date
    Sep 2004
    Location
    Lake Villa ILL.
    Posts
    50
    Looks like they may have been internal hex cap screws, picure #2 looks like there is a shoulder. When installed the head of the screw would be flush with the plate.
  4. #4
    Join Date
    Apr 2012
    Posts
    23
    Quote Originally Posted by The Buda View Post
    +1 - it does look as though there was a hex opening on the top.
  5. #5
    My Boats:
    2004 Chaparral,26 Donzi,14 Browning
    Join Date
    Jun 2006
    Location
    SW Florida
    Posts
    76
    The studs have a female hex. You start the nut on and then hold the stud from turning as you tighten the nut....as I remember.
  6. #6
    My Boats:
    Join Date
    Aug 2010
    Location
    Tacoma, WA
    Posts
    137
    Yup, it turns out it was female hex nuts that worked. When I took it off I had to drill them out, so I wasn't really sure what was in there to begin with because they where pretty deteriorated.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Powered by vBulletin® Version 4.2.0
Copyright © 2013 vBulletin Solutions, Inc. All rights reserved.
Search Engine Optimization by vBSEO 3.6.1
