Purge MPI system
purge MPI engine fuel
OK, I will find out shortly. I will go with my original plan as long as the pump gets gas, the air should be expelled !
Sounds like a pun !
Sounds like a pun !
Inserted primer bulb and primed/pressurized the fuel system several times. Cycled the ignition switch several times. I tried "start" and got little efforts to start. re-primed and after some more tries it started. Not sure this is the best way to put a F.I . back in service. P.S. I did check the shrader valve and just got a bit of gas. No air, no spray. so pump was air locked and not building up.
