Cam Size 454
#31
Registered User
The only bummer to all of the fun in spec'ing out a roller cam, rockers, intake carb and exhaust is that I get to do it twice when you've got twins to upgrade. Two of everything to buy! But no one said boating was cheap.
#32
Call UltraDyne "Bulletracing cams" and talk to Tim Goolsby He will dial you in Don't buy a cookie cutter camshaft thinking it will work do a custom grind for your set up. 662-893-5670
And go with a roller set up to get the most out of the camshaft you can A flat tappet non roller is a part of the pass and you will be loosing so much performance out it too.
