Register
If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Follow us on Facebook Follow us on Twitter
Results 1 to 8 of 8
  1. #1
    My Boats:
    1988 Baja Sport/Outlaw
    Join Date
    Aug 2007
    Location
    St.Louis MO
    Posts
    633
    502 mpi too 500hp conversion..
    I have a 96 502 that started life as a mpi 415 horse motor. But now I have removed the MPI, and put a dart high rise intake, and a hp500 850 and I have emi exhaust on it. It also has roller lifters and a upgraded merc roller cam. I wanna make 500 horse. So what am I going to need to make 500? Im not sure I will even see a difference in MPH over what I have now...I run right at 70 gps now.
  2. #2
    Gold Member Gold Member swan2's Avatar
    Join Date
    Jul 2007
    Posts
    187
    Procharger
  3. #3
    Platinum Member Platinum Member MILD THUNDER's Avatar
    My Boats:
    1990 38 Fever SSM IV
    Join Date
    Jul 2004
    Location
    chicago
    Posts
    4,262
    What cam do you now have in it? Really the only difference between the HP500 and your old engine, is
    CAM
    INTAKE
    CARB
    EXHAUST
    ROCKER ARMS
    A good cam would be a 525EFI merc cam or similar.
  4. #4
    My Boats:
    Join Date
    Aug 2007
    Location
    St.Louis MO
    Posts
    633
    so basicly all I need that is different from my motor and what I have done already is a cam and rocker arms..
  5. #5
    My Boats:
    1997 Stingray 230SX, 502 MAG MPI
    Join Date
    Jul 2011
    Location
    Chicago, IL
    Posts
    39
    Heads are different from what I understand.
  6. #6
    My Boats:
    Join Date
    Aug 2007
    Location
    St.Louis MO
    Posts
    633
    what heads are on a 500hp? I know they arent aluminum...
  7. #7
    Charter Member # 55 Charter Member Griff's Avatar
    My Boats:
    ............................... 32 Active Thunder
    Join Date
    Oct 2000
    Location
    Omaha
    Posts
    12,284
    Heads are the same. They are GM rect ports. The 500HP's might have slightly bigger valves.
  8. #8
    Platinum Member Platinum Member mcollinstn's Avatar
    My Boats:
    1991 F311SR1
    Join Date
    Sep 2001
    Location
    tn
    Posts
    5,415
    Quote Originally Posted by stlliberator View Post
    It matters what cam you chose. "A cam" can make or break a motor. What did you put in it? Did you verify that your stock lifters will work with the new cam's lift?
    Your heads are the same as an HP500, and your valves are the same size. The HP500 does have upgraded valves, but not for more power, they are for better longevity.
    I see London, I see France...
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
OSO Sponsor
OSO Advertisers
OSO Directory
Powered by vBulletin® Version 4.2.0
Copyright © 2013 vBulletin Solutions, Inc. All rights reserved.
Search Engine Optimization by vBSEO 3.6.1
