Register
If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Follow us on Facebook Follow us on Twitter
Results 1 to 6 of 6
  1. #1
    My Boats:
    1979 spectra 32
    Join Date
    May 2011
    Location
    OC california
    Posts
    40
    oil bypass valve Mark iv
    I have looked but cant find anything specific to the mark iv's. Is there a bypass valve in the block I need to worry about. if there is, where is it and can I just block it off.
    Pictures would be great.
    My oil pressure is all over the place after a rebuild. pulling motor to change oil pump out. seems like the perfect time to take car of this.
  2. #2
    My Boats:
    77 donzi x18 92 formula 336 sr1
    Join Date
    Aug 2005
    Location
    Between A Womans Leggs in IL
    Posts
    4,559
    fixx
    Quote Originally Posted by killfast1 View Post
    i believe their is a oil filter bypass where the oil filter would go on the block..the oil pressure valve is in the pump,the oil pump you want to use is a 10778c..this one has the anticavitation grooves in the body and grooves..
  3. #3
    Platinum Member Platinum Member picklenjim's Avatar
    My Boats:
    83' Nordic 23' Viking 505 BBC TRS Drive
    Join Date
    Mar 2009
    Location
    OFallon,Mo.
    Posts
    1,431
    Only one is on the oil filter pad. I replaced mine with one of these.http://www.summitracing.com/parts/SME-2015/
    Then for safety I run the K&N HP6002 filter which has a higher burst pressure rating and the extra filtering capacity. Remember now all your oil will be going through the filter.
  4. #4
    My Boats:
    1979 spectra 32
    Join Date
    May 2011
    Location
    OC california
    Posts
    40
    Quote Originally Posted by mrfixxall View Post
    Thats the one I have. gonna put it in tomorrow.
  5. #5
    My Boats:
    1979 spectra 32
    Join Date
    May 2011
    Location
    OC california
    Posts
    40
    I have seen the thread and pictures for the gen 5 and 6 blocks, but cant seem to find anything for the old mark 4. This is a new block so not even sure its in it. So need to know which opening needs to be blocked off.
  6. #6
    My Boats:
    Join Date
    Mar 2009
    Location
    OFallon,Mo.
    Posts
    1,431
    It's not "in" the block on a mk lV. They bolt to the block on the filter pad and the filter spins onto it in a stock application. Here's what they look like.
    http://www.jegs.com/p/Mr-Gasket/Mr-G...93641/10002/-1
    If you want to elimanate it you use a plate like I posted in my earlier reply.
    If there are only 2 large holes and 2 smaller threaded holes. You don't block any. The large hole coming in at an angle from the side comes "IN" from the pump. The other large hole in the center goes "Out" into the engine oiling passages.
    Be sure with that pump you use the drive shaft with the steel "pinned on" coupler.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
OSO Sponsor
OSO Advertisers
OSO Directory
Powered by vBulletin® Version 4.2.0
Copyright © 2013 vBulletin Solutions, Inc. All rights reserved.
Search Engine Optimization by vBSEO 3.6.1
